8800GTS - Overclocked
1 Feb 2006
Hello,
I have just bought one of these 8800GTS, the OC version, 320MB.
I am very impressed with it to say the least. I have used nTune to overclock it, and because I am a noob at OC, i just pressed the "find optimal" button.
The results seem quite high.......
The GPU is 658 from 513 stock.
The Memory is 986 from 798 stock (doubles i know because its GDDR3)
I have played a few games and nvTray reports the speeds as correct, and the card is rock steady. I'm just shocked how easy it was, and by the size of the increase.
Am I fortunate or is this normally the case?
-Hotplate-
most 8800GTS`s should do 650/1000 with stock cooling, of course a few that dont.
Slightly disagree with you. I haven't found anybody who can't do 621 but there are quite a few which will only do that and no more. More than a few.
Almost as many people can get to 650.
The really, really lucky handful, and there aren't many, get 700.
One or two people on these boards have and a few review sites have had cards where they got them to that speed however, they may have been sent "good" cards in the first place.......
Hello,
-Hotplate-
Well done on getting ntune to work. It hangs mine as soon as it increases 1 Mhz yet ati tools gets it to 650.
Good overclock that btw. Now try rivatuner 2.05 and see if you can get your shader clock any higher
