8800GTS upgrade to ???
8 Oct 2005
Cumbria
My 8800TS 512mb is struggling with MW/WAW (1680x1050) and think i need an upgrade before MW2.
Max i want to spend is around £150 (new or used) as i also need a block for it.
Not bothered about bench scores just fps :confused:
For that kinda price range i'd say the 5770 is your best bet or if you want to save abit more go for the 5850
Price/performance is very high, full current-gen featureset, add a 2nd card for 5870 performance whilst still remaining cheap.
Very happy with my two for the cost.
sadly a second card isnt much of an option due to the full cover blocks being £70 a time, in theory it would cost me £400 for 2 5770's so looking for the best single card set up.
Although i do prefer nvidia, my only real options for £200 all in with a block seem to be:
5770
GTX 260
4890
4870 x2
Although i'm edging away from the 5770 due to the fps hit and not much interest in DX11.
Personally either get a 4890 or gtx260 used as they are going cheap and even plenty of blocks around so you should get both for well under £150. I was selling my gtx260 216 SC with full ek block for £130.
When I went from my 8800gts to my gtx260 it was a massive boost at the same res you play.
Downside is no dx11 support and depends how you feel on that. If you think that's important then get a 5770 as that almost within your budget (but still over with a full block unless you go for just the core block and ramsinks)
EDIT: Just realised your budget was £150 without the block. My post still stands though as the ones I said will more than do for a fill in. The 5770 is not far short of 4870 speeds so slightly less than gtx260 216 but you gain dx11 and it's performance will only improve with drivers. I wouldn;t blow my whole budget on old tech though.
the 4870 X2 needs its own waterblock not a 4870 waterblock etc
They all need different blocks but i can get the x2 one for £40 ;)
I put a £150 budget for the card only (£200 all in) which just covers all 4.
I personally can't see DX11 being an issue, i dont play many games and by the time i move on these will be dated lol
Thanks for all the inputs :)
