Just about to start OC'ing my 8800GTX.
I looked and noticed that idle temp was at 56c and during 3dMark06 maxed out at 69c.
Fan is set to standard settings.
Assuming I ramp the GPU fan up to 100% during overclock tests, what sort of max temp should I stay within?
Thanks.
Thanks.
Great help, again! Cheers.
Is your system stable in games? Most 8800 cards fall over at 85 degrees so your fan going 50% at that temp won;t help at all IMO. You will even hit the termal shutdown of the card before you hit 100% fan speed
