Overclocked my 2 880GTX's (riva tuner)
from 575mhz core
1350mhz shader
1800mhz memory
to (45-50 + on each value)
620mhz core
1395mhz shade
1900mhz mem
small increase to start with! temps run at 66 c load (using 3d mark 06)
what other things should I use to check stability? and if ATI tool with that 3d furry cube thingy, then how long for? and should I scan for artifacts or let it rotate? gets real hot doing that for a while though (high 70's at normal clock speeds)
please just a little guidance, Many thanks
from 575mhz core
1350mhz shader
1800mhz memory
620mhz core
1395mhz shade
1900mhz mem
