8800gtx problems
10 Sep 2006
Manchester
When i try to play counter strike source , the screen goes all funny for eg:
It will all go brown and i will see triangles and lines etc.
This only started happening a few hours ago.. i'v tried restarting my pc etc but still no luck.
I havn't overclocked or changed the heatsink at all , everything is stock.
Temps while i play is around 80degrees :S (when i could play :P)
is my card broke(RMA IT?) / overheating
Try games made this century, some modern and more demanding ones. Sounds like a driver problem to me, reinstall your drivers (after removing the old installation) or install newer drivers if there is anyout.
i do know that the 8800 series has a problem with the source engine and valve are working on a fix for it but that looks like a driver problem
*edit* gdgd
