I know i'l see improvements, as i did with my 7800gtx under water, its specifically a 8800gtx temp im after.Street said:Well if my X1900XT is anything to go by, you should see massive improvements.. Its dropped my idle temps down to below 40C and my load temps never really go about 45C and thats overclocked with a [email protected] on the loop!![]()
Cheers mate, im getting 75 at idle atm. Should be able to push the core speed a little more.Lolcb said:42-46 idle
Cheers mate, same as the 7800gtx then.Jokester said:Note they won't likely get you a better overclock as 8800GTXs are volt limited not cooling limited.
Jokester
Romper76 could you answer my post about the EK 8800gtx waterblock here please http://forums.overclockers.co.uk/showthread.php?t=17731837romper76 said:well i put on a ek block and ..........
http://forums.overclockers.co.uk/showthread.php?t=17693233&highlight=water+block
Jokester said:Yep, mine dropped to about 40-45C with Maze 4s.
Jokester
My 7800gtx idled at 35-40C.topgun06 said:Should see decent drops! My 7800's used to idle at around 70 degrees, but now with water cooling they are around 40. Thats 40 degrees on both cards, in SLi and, an over clocked e6600 to 3.1ghz.
elfy said:how well do the 8800s work with maze 4s? do you have to have ram sinks on as well?
Yeah i didpegasus1 said:My 7800gtx idled at 35-40C.
Off topic. Did you go to the Derby game last week? im not a Derby or Southampton fan but went in the away end, what a match.
i was just to the left of the goal (as you look at it) during the pens, got absolutely soaked waiting for a mate to pick me up.topgun06 said:Yeah i did![]()
Was a great game, i was crapping myself during the penos!
Yeah weather was terrible. We park at a friends house about 30 mins walk away from the ground. Up until that day, in 3 years we have never got wet walking to or from the game. I had never been so drenched in my life!pegasus1 said:i was just to the left of the goal (as you look at it) during the pens, got absolutely soaked waiting for a mate to pick me up.![]()
Jokester said:They don't as such, I glued mine on to the IHS. You don't need RAMsinks.
Jokester
