8800GTX Updates
29 Jan 2007
Ritefast HQ
Hi can anyone help me on how to update my graphics card just put new pc together at weekend got the home premium vista on there inserted graphics driver cd but said its unable to install drivers because of it not being xp would do it on the internet but dont have wireless setup also dont know how to :(
TheDean said:
Jimbo - Can I just ask - Did you have any issues fitting your GTX into your P180? I'm thinking of flogging my GTS and getting a GTS with more memory as I've just bought a 24" Dell beast...
Only problems I had was I had fitted a fan on the heatsinks nb/sb and had to take it of because it wouldnt go in the slot. Other than that it fits just fine.
Cheers for that Jimbo - The reason I ask is I currently have a 320MB version and have just splashed out on a 24" Dell and want to play all my games at high res - I'm thinking of selling the GTS 320MB and buying a GTS 640MB - DO you think this is a good plan for another £80?
Might be worth getting the GTX if you've got a 24" screen. The differance between the GTX and GTS is more apparent higher resolutions.
I couldnt really comment mate, on wether its worth it or not. I just know my 8800GTX will kill anything at any res, I reckon at the end of the day its about how fast your core/mem is, rather than amount of mem on board. Just get the best you can afford. ;)
