8800GTX vs HD4870
18 Oct 2002
Fife
Is there a big difference in the two cards - just bought one 2nd hand of the marketplace and, instead of puting it into my dads rig was thinking of keeping it for myself ?
I have to upgrade his systenm next week so bought the parts to do the job but giving him my parts is an option and I keep these ones.
Trouble is its in a water cooled rig just now and not sure that I can be bothered with the hassle.
Is there a good cooler for the 8800 GTX if I took it out of mine and put it in his?
That cooler wont fit!
I ordered last week for mine!
Also dont use the thermal pads that come with it on your standard cooler!
I done this and it creates a gap between GPU and cooler... Idle was 110C
Removed them and used AC5 instead and GPU under load is now 60C and 45 idle!
