Hi,
Bought another 4GB (2 x 2GB) OCZ 8500 platinum DDR2 memory for my Asus P5Q deluxe. I'm having some issues though....
Firstly, when I installed the memory I had problems with XP64 crashing, pretty much just after loading up to desktop. Tried both sets on their own with it and they are fine. Its only when I use all four it gets unstable, and generally very quickly. Tried the various tweaks I've read about (bit more volts here and there, slacking the timing etc) and also updated the bios to the latest version.
Its improved a bit with the latest bios version - I've tried using all auto settings but that hasn't helped...
...now the odd thing is when I use XP32 (dual boot) I have no problems at all. Surely of the issue is timing for 4 dimms wouldn't it effect the os regardless of how much of that memory its using?
Going to leave memtest running overnight on the full 8GB and see it it detects anything at all. If it doesn't then it must be an issue within XP64 and 8GB? I'll try a 64 bit linux boot cd and see if thats stable...
...any ideas?
...any ideas?
