So Intel have indeed brought out the big guns with the launch of the i9 12-18 Core CPU's.
In response to this I have designed some very flexible high end bundles for our customers to take advantage of. If you don't want to buy a pre overclocked bundle then of course you can buy the delidded binned CPU's and overclock yourself. I am doing all the OC on these ones myself.
The minimum cooling for these beasts is a custom triple rad solution and above, of course a quality PSU and either ASUS Rampage 6 Xtreme, Rampage 6 Apex or ASrock X299 OC Formula motherboards as these have the best VRM cooling available right now and overclock very well too.
OK so lets get onto the bundles and show some bench marks:
Each bundle you can choose the following CPUS:
7900X @ 4.8ghz, 7920X @ 4.7ghz, 7960X @ 4.6ghz, 7980XE @4.6ghz.
Motherboards: ASUS R6E, ASUS R6A or ASrock X299 OCF.
Memory: 8Pack dimms 32gb, 3200-3866mhz (4000mhz+ on 7900X)
Cooling: EK fluid gaming 360mm Kit or above...........
Here we have none AVX prime stability testing for each CPU using an Asetek 360mm rad so obviously you will get better temps with a custom solution and this is very much worse case scenario.
Here are some bench mark tests of what performance the end user can expect from these bundles. I used Cinebench R15, Realbench and Terragen to show CPU performance in heavy duty applications.
First the 18 7980XE 4.6ghz
Now the 16 Core:
12 Core:
and Finally 10 Core at 4.8, 4.9 and with 2 cores at 5.0ghz.
Any questions about these benches or tests obviously let me know.
I am sure you will all recognise that these bundles have serious power and Intel have truly taken back the performance crown.
The buy the bundles follow these links:
https://www.overclockers.co.uk/detail/index/sarticle/69599
https://www.overclockers.co.uk/detail/index/sarticle/69605
https://www.overclockers.co.uk/8pac...ocked-enthusiast-gaming-bundle-bu-00m-8p.html
To pre order binned CPU's follow this link and select your required CPU.
https://www.overclockers.co.uk/pc-components/processors/intel/socket-2066?sSort=4&ckTab=0
If you need to make any minor adjustment to the bundles please call sales.
Videos to follow.
Now the 16 Core:
12 Core:
Videos to follow.
