8Pack Binned 5960X - 4.7 GHz
25 Mar 2016
Hi 8Pack,
I recently purchased one of your I7 5960X CPUs binned at 4.7 GHz. The expectation from item description is that I should see 24/7 stability at 4.65 and bench stability at 4.75 Ghz with custom cooling.
Since I don't know what voltages you used when binning this CPU, I'd appreciate it if you could take a look at the numbers I generated along with the temperatures from my custom loop and comment on whether I'm hitting the performance you'd expect from this CPU at the voltages and temperatures you'd expect.
First, I assume that the synthetic "non real-world" stress tests such as AIDA64 Extreme and Prime95 Small FFT (Especially the versions with AVX instructions implemented) are not representative since at speeds in the 4.65 - 4.75 GHz range, these synthetics are going to shoot straight up to 105°C and throttling will occur (or the system will freeze/BSOD or threads will drop out). So this leaves more "real world" benchmarks like the AIDA64 Extreme benchmarks (not the stress test, but the benchmarks), Cinebench 11.5 and R15 rendering, and the RealBench H.264 Handbrake rendering benchmarks. Finally, I wasnt pushing the cache or memory to the edge so as to not complicate the stability picture and stuck to adjusting Vcore, Vinput, and LLC level and didn't try to get cute with Vccsa or other voltages/settings.
So, here's what I got:
4.65 GHz (46 x 101.1)
(Looking for 24/7 stability)
VCore = 1.325 Volts
Vinput = 1.95 Volts
LLC = Level 6
Everything else set to Auto
180 minute loop - stable
Max single core temperature: 79°C
4.751 GHz (47 x 101.1)
(Looking for bench stability)
Vcore = 1.45 Volts
Vinput = 2.0 Volts
LLC = Level 6
AIDA64 Extreme Benchmarks
Full list - stable
Max single core temperature: 104°C (ouch)
Cinebench 11.5
CPU Render 10X one after another - Stable
Max single core temperature: 94°C
Cinebench R15
Max single core temperature: 92°C
Intel XTU
CPU Stress Test
10 minutes - Pass
Max single core temperature: 98°C
10 minute loop - stable
And that's it. I've got to run more benchmarks and stability tests to for the 24/7 stability at 4.65 GHz, but the 180 minutes of RealBench handbrake is a good start here. At 4.75 GHz, passing all the tests on a 10 minute loop with no failures should be sufficient to demonstrate bench stability.
Questions:
1. Is my Vcore at 4.65 GHz of 1.325 volts about what you would expect/want for a 24/7 stable system?
2. It took a 0.125 volt Vcore increase to step up from 4.65 to 4.75 GHz (1.325 volts at 4.65 GHz to 1.45 volts at 4.75 GHZ). Is this reasonable? Some of the more aggressive benchmarks and tests pushed 105°C. I wouldn't ever want to try to run like this 24/7 since cooked CPUs are costly, but for short benching sessions, does the Vcore of 1.45 volts seem acceptable/reasonable at 4.75 GHz?
3. What other benchmarks/tests would you recommend for further stability testing at 4.65 and 4.75 GHz?
Overall, a fine CPU you picked out for me!
Your cooling is way off binning is with a triple 120mm Rad loop. But I am not getting close to those temps. Why would you run AVX Prime etc when you know your temps are so high??
The binning process is 4.75ghz+ XTU and Cinebench R15 1.3v tops XTU Cache 3.5 memory 3000mhz 16gb quad channel ASUS R5E. All these chips are 4.625ghz 24/7 on good cooling and correct Bios settings for everyday use with 16gb RAM. You need to keep the CPU at much better load temps.
Deciding what benchmarks to run is a real problem since you can ask ten "experts" and none of them will ever seem to agree. Will take your opinion over the others any day and stick with XTU & Cinebench to try to duplicate your binning. Specifically didn't run AVX P95 since it's brutal and I can't imagine any real world situation that's going to relentlessly slam a CPU with AVX.
Will revisit the voltage at 4.75. Cooling is via a dedicated triple 120 loop w/Phobya UC-2 LT CPU block and 4 meter pump, Kryonaut TIM. I had the cache at 4200, so I'll drop it back to 3500. Will also re-apply the Kryonaut. At 4.75 XTU was 98° and R15 was 92°. Both were stable but Vcore was 1.45 which did seem much too high. 1.3 volts should drop those temps into the 70's assuming I can suss out why I needed so much voltage in the first place.
I've always had good results finding where a CPU sits with XTU and Cinebench and then being slightly paranoid bumping the voltage one notch (aslong as that doesn't destabilise it with extra heat which 99% of the time it doesn't) - so far never had a system flake out in normal operation after passing that kind of testing.
Keep an eye on your VTT as well (or whatever it is called on your board) - past a certain level you can see the temperatures jump up quite a bit.
A 360 rad should handle a cpu comfortably so i would try and troubleshoot that first and find out why its not getting rid of all that heat.
Your cooling is not doing its job at all. You need to fix this first. I am running any stress test and not going above 80C here on a quad solution I currently have installed. I mean above 100C is simply crazy and can damage the CPU.
To test stability use the system as you normally would.
XTU with say Heaven to stress PCI controller is a good synthetic stability test as its maxing out all controllers. Also try Real Bench this is good real world synthetic test too.
Turns out the CPU block is bowed pretty severely. I've not run into one like this in years, so I guess I got complacent and didn't verify flatness before installing it a couple weeks ago. Nothing a couple hours of lapping or an exchange won't sort out.
Thanks for the input guys. Got the block flattened out and also opened it up and found it pretty fouled with gunk around the restrictor plate (which is odd since it's new).
4.65 GHz @ 1.275 Volts
Cinebench R15 (20X) @ 67°C
Intel XTU (60 minutes) @ 70°C
4.75 GHz @ 1.40 Volts (can't get it stable any lower)
Cinebench R15 (20X) @ 80°C (was 92°C before)
Intel XTU (60 minutes) @ 86°C (was 98°C before)
Much better than the first time around. 12 degrees cooler at 4.75 GHz.
I'm happy that I can run at 4.75 GHz, but the sweet spot obviously is a bit lower since I can do 4.65 at 1.275 volts and keep the temperatures at or below 70°C.
You say the block is new so is the radiator new as well? If so did you flush it out thoroughly before use? If not you should strip it all down and do it now. Check the block again too.
Yea, flushed everything. Initially, I just ran water through the radiator for a minute. After I found the crud in the block, I took off the radiator and shook it hard 3X with hot water inside.
Pretty happy with my 4.65 GHz temperatures generally in the upper 60's to 70 now.
I use filtered deionized water at 2 MΩ/cm, no additives. I hit it with a UV light from a water sterilization pen for a couple minutes every few days. Nothing grows.
