8Packs Xtreme X99 Bundle 4.6ghz+ 5960X goodness!!
OcUK Staff
20 Feb 2012
John Smiths Stadium
This is the first 8Pack bundle we are offering where I am doing all the overclocking for the customer. This includes RAM tuning and stability testing. Each bundle will be fully set up with OC profiles saved in the bios ready to be simply installed into the end users case.
Due to high heat output of this Overclocked CPU we are supplying either a custom loop dual Rad solution as standard. As an easy alternative to a custom loop dual we have an AIO 360 and for the absolute top performance as a further upgrade a triple rad custom solution.
We are using the top Bin 5960X in this bundle to ensure the highest overclocks and stability. Kingston Predator 3000mhz mems as it can go both high and tune well and finally Gigabytes OC Champion X99 motherboard as its very solid and the best overclocking X99 offering bar-none.
Pics of the bundle set up prior to testing.
First some stability testing.
So lets see some performance numbers of the minimum Overclock at work.
Terragen 3 Rendering test.
Cinebench R15 Render testing.
Firstrike Xtreme and Firestrike Ultra 4K Benchmarks (980Ti Stock)
Heaven.
Sleeping Dogs and Bioshock Infinite Maxed out.
This bundle is offering the best possible performance across all the tasks any end user could throw at it.
To find out more about this upgrade bundle or to place an order follow this link.
https://www.overclockers.co.uk/detail/index/sArticle/59340
