90 degree compression fittings
10 Mar 2009
im looking for:
1/4" BSPP - 1/2" ID - 3/4" OD 90 degree compression fittings but cant find them anywhere.
All I can find is the koolance ones with 5/8" OD so I would have to shave some of the tubing to get them to fit properly.
Are there any of these fittings available in the UK? I can find 45 degree but not 90. Is there a reason for this?
Are there any good barb alternatives?
thank you
