90 degree fan mount?
20 Oct 2007
This is something I've ignored for years but really need to fix.
I have a CM Stacker 830. This has a side door with 4 fans (pic: http://content.hwigroup.net/images/articles/stacker_830_van_informatique_550.jpg , see the door on the left with 4 fan mounts).
The problem is, if I put the radiator from my Corsair H50 at the back of the case, the door can't be attached. To remedy this, I've been wedging the radiator above the hard drive bay at the front of the case.
Clearly this isn't ideal! ;) Albeit a "temporary solution" that's been like it for 4 years :p
The simplest solution is probably a CPU cooler that doesn't use a radiator but I'd rather keep the H50 as it's quiet and works perfectly well.
Is there such a thing as a 90 degree fan mount that would let me mount the radiator in the rear fan bracket so it faced the motherboard? This would allow it to sit parallel to the door that I can't shut with it at the back of the case.
Other suggestions are welcome of course!
