90 degree fittings
18 Oct 2002
Sutton Coldfield, Birmingham
Is there a limit as to how many 45 degree and 90 degree fittings you should use as I presume they restrict flow? Playing with ideas (already :rolleyes:) about making the tubing a bit neater and in theory I'm looking at using 4 45 degree and 2 90 degree fittings.
Would this be ok or am I restricting flow way too much?
fittings have VERY little resistance, you should see how small the channels are in your rads and CPU :D
its not the resistance of the fittings, the problem is that eddies form which continually suck energy from the system and so reduce pressure/flow rate
eddies? What are they?
when a fluid makes a "significant" turn, anything more than 45 degrees or so, it cant turn like the fitting is trying to make it. To compensate for this, a little whirlpool or eddy is made at the fitting which continually sucks energy from the system, reducing performance
this is from fluid dynamics, i dont know the significance of this in practical water-cooling, but it is interesting nevertheless :)
that's brilliant news, cheers guys :)
Pump is a DCP 4.0 so it should be ok I would have thought? There's only the CPU block and the 360 rad in the loop for the time being.
Stolen from skinnee
EK 4.0 -> Supreme HF P4 -> MCR320 -> Res.
Normal: 1.80GPM @ 13.8W
1x BP 90 @ Inlet: 1.77GPM @ 13.7W
2x BP 90 @ Inlet: 1.74GPM @ 13.6W
3x BP 90 @ Inlet: 1.71GPM @ 13.4W
4x BP 90 @ Inlet: 1.64GPM @ 13.2W
Shouldnt see much of a difference + x2 45 degree angles = 1 90 degree angle.
found a direct quote to explain it better :)
Restriction is anything that impedes flow, thereby reducing the amount of energy in the water - and it happens to some degree or another any time anything is in the way of the flow of open water. For instance, if you have a 90 degree elbow in your loop, the water is rushing towards it and slams into the wall of it before diverting its path. This "slows the water down" - it impedes its natural flow.
How? Remember your laws of inertia, and think of it like this: as a water molecule moves in the pipe, it wants to continue to go the way it already is. Obviously, it doesn't just naturally turn - it continues until it cannot (collides with the elbow wall). This means it has to stop, and then has to start again in a different direction - which it has to borrow energy from its neighbors to do.
Restriction is created by sharp turns, sharp decreases in path volume (i.e., a spacious block crammed back into an 8mm ID hose) and things in the general path of the water. The more restriction there is, the more head pressure from the pump is needed to compensate for it, which means more noise and power.
