£900 Build Check
26 Jan 2012
London
Great. I guess the case is down to personal preference and it has decent airflow. Should I go with 970 or AMD equivalent?
Cheaper Ram. Also a fully modular psu will make cable management a bit easier in a small case.
My basket at Overclockers UK:
Total: £140.44
(includes shipping: £10.50)
You only get a single rear fan pre-installed in the aerocool case, so I would suggest you buy a couple of fans for the front to get some airflow going.
Outside of benchmarks the gains will be almost imperceptible - not enough to warrant the extra cost of 3000mhz over 2400mhz
