^ The case doesn't come with the ones above the motherboard. A thick push/pull rad will cover the holes anyway but I know Kaapstad has his external. I've asked some custom shops if they have the ability to make these and none do.
I would like some for mine too though, perhaps raising more interest on Corsair's forum will help. I will make a thread there later?
I've even looked at a few pics comparing it to the ones in the 350d but they seem a lot longer and thinner. There are however two top grommets in the 350d that could possibly work.
If you've got some height and width measurements I can check the sizes and get back to you.
They won't fit in the spot marked in red, that's just an image I'm using to look at the 900D. But they might work in the 4 holes above.
*Edit
Measuing the holes they fit into there are roughly 22mm x 76mm.
