92mm Fan
9 Mar 2005
Wakefield
Looking at getting a new fan for my shuttle to replace to cpu fan.
Any ideas what the CFM is on the stock fan?
Are there any 92mm fans out there that shift more air with less noise?
I was also thinking about taking out the whole thing and attaching a 92mm-120mm adaptor and putting a 120mm fan on the outside?
Which would be the best route to go, or should I stick with what I have?
just found out that the fans inside are able to do 50 CFM at full speed, im running mine at 2000rpm out of the 3600ish at full power. at a guess im getting 28 CFM at the mo so a quieter Xilence fan doing 36 CFM at 1500RPM seems a good choice
