92mm Fans
3 Jul 2008
Fife way up in Scotland
Looking for just a wee bit info here,
Needing 3 92mm fans, my Antec Titan case only has one 12mm exhaust fan and im looking at puting a 92mm on the side as an exhaust from GFX and then two intake at front directly infront of the HDD's
Im looking for ones that are quiet but will do the job nicely, When it comes to cooling i havent a clue on fans, also i was hoping to be running them from a Fan controler what would be recomended here, it doesnt have to be all singing and dancing just the 2 onboard fan ports are being used and would rather run them from psu and have control of them
Cheers, thats the Fan Controller i was looking at, it doesnt have to be astheticaly pleasing as it will be behind the case door so that will more than likely do.
Like the look of the scythe Typhoons,
Which CPU cooler would be recomended, i have a Q6600 sitting at stock but intend on pumping it up a bit, just now its running around 45 idle which imo isnt the coolest for idle.
That may be because theres no cool air being drawn in tho. am i right?
I fancy a nice looking CPU Cooler but nothing ridiculous.
Also been looking at
Corsair Dual Cooler
Worth it or not?
Also how do you trn on the HTML coding?
Personally I would say not worth it for the Corsair RAM cooler.
I put mine on my 4GB Dominator as soon as I got them, but it's fairly loud (those 3 little fans go at quite a rate), and unless you're overclocking the breasts off your RAM then the extra couple of degrees probably isn't worth it.
I have one of these:
http://www.overclockers.co.uk/showproduct.php?prodid=FG-001-XI&groupid=701&catid=57&subcat=820
on my old 8800GTX's Thermalright HR-03Plus. Nice and quiet, and provides good airflow.
If you want to spend a bit (quite a bit) more, the Noctua fans are excellent.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-005-NC&groupid=701&catid=57&subcat=820
I've got 3 of the 120mm version in my Lian Li, wonderfully quiet, and a good amount of airflow.
For CPU cooler, the Tuniq Tower (single fan), Thermalright Ultra Extreme (single or dual fan) and Noctua NH-U12P (single or dual fan) are the general recommendations.
So, heres what i aim to have, 1x12mm exhaust fan. 1x92mm side fan exhaust from gfx, 2x92mm front fans to cool HDD and to pass cool ait to GFX.
1x fan on mobo heatpipe heatsink drawing air from mobot to exhaust fan.
Sufficient cooling? usualy just gaming i do but not to much
Does anyone think this will have cooling power?
Cool Master V10
What the?!? Surely it's not THAt big, is it? That'll break your mobo if you vertical mount your board....
You would need a ratchet strap to keep it on.
Apparently it is real. im interested what mounting plates are used to keep the beast on.
Prices dont look very nice either
Holy **** that is a massive cpu cooler, you would need something strong to keep in from falling out.
If you need a cpu cooler this powerful i would just go watercooling tbh.
I googled it now, and according to some review sites, it doesn't perform much better (if at all) than the V8.....
