Well I have never been happy with the 2x92mm fans i choose for the rear on my case, thought would look quite good with white LED on smoked frame but they are just a bit too bright, here is a pic I just took now with one of them in:
As you can see quite bright and don't really go with the colour scheme been aiming for so bought some LED's (quite a while ago, been putting this off!) and finally got round to replacing the LED's in one of the fans:
Think will look great when its back in the case, just got to do the other one now. Had some problems with the wires and the soldering on the PCB board was dodgy so had to replace a couple of wires:
Have also found a new novel use for the 92mm fan grills!
Will post pics up when done the other fan and back in the case
