9500gt card
18 Jan 2009
Hi I currently have an old 8500gt card in my pc and the only game I play is World of Warcraft. It plays fine on my 22" monitor at about 30fps which is all I need.
I installed the new expansion and it is more graphically demanding - my frame rate dropped down to 25fps.
I found a very cheap 9500gt card, will I notice a better experience with this card instead of the old 8500gt?
Thank you
If your prepared to buy a new GPU anyway you might want to try overclocking that 8500GT - should be able to get around 80% performance boost if its like the ones I had (with shader/core unlinked).
