950w 80 Plus Silver certified PSU!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
We have a great deal on the PC Power and Cooling 950w Silencer mk2 PSU's.
Stock will be landing Friday/Monday. This is the best priced high end 950w PSU on the market. Exclusively at OcUK too.....
PC Power & Cooling Silencer Mk II 950w '80 Plus Silver' Power Supply @ £104.99 inc VAT
The new Silencer Mk II 950W from the power supply experts at PC Power & Cooling is another leap forward for the legendary Silencer line. A thorough update, the new Silencer Mk II strikes the right balance between server-class industry standard topology and the cutting-edge of enthusiast computer power supply design. Built with industrial and professional power users in mind, key features of the 950W Mk II include a Single +12V Rail for maximum and efficient power distribution, a generous thermally controlled 135mm double-ball bearing fan for maximum airflow at near-silent audible noise levels, extremely tight and well regulated electrical noise and ripple, an ideal array of connector types for each wattage, and ultra-high efficiency, converting up to a full 88% of AC to DC power at typical loads. The Silencer Mk II Series is fully compliant with the latest ATX12V and EPS12V specifications. Power-packed and built to last with a 7-Year Warranty.
- 950W Continuous @ 50C
- NVIDIA SLI Certified (Dual GPU)
- 80+ Silver Certified (88% Efficiency); .98 Active PFC
- 135mm double ball-bearing fan
- Up to 90% (10dB) Less Noise per Watt
- +12VDC @83.4A (Powerful Single Rail)
- Rock-Solid, Super-Clean DC Output
- 6 x PCI-E and complete array of connectors
- Automatic Fan Speed Control Circuit
- 7-Year Warranty and Tech Support
- 1 x 20+4 pin motherboard connector
- 1 x 4+4 pin CPU connector
- 1 x 8 pin 12V connector
- 6 x 6+2 pin PCI-E connectors
- 7 x molex connectors
- 12 x SATA connectors
Normal Price - £119.99 Inc. VAT
PRE ORDER PRICE £104.99 inc VAT.
ORDER NOW
