955be..When is it too hot?
Nobody has mentioned ambient temp yet. It can have a drastic effect on the cooling of the machine. What is the ambient temp and what case/fan setup? There's actually more to CPU cooling than just the CPU cooler!
i dont know the ambiant temp in here, its not hot and its not really cold - i odnt that doesnt really help
its the CoolerMaster Scout case with the basic fans and 2 x 120mm side fans
I have that case but with out any fans on the side panel.
how do i set fans to run at max at all times?
i dont really mind about the noise as my speakers are closer so they would drown most (if there is that much) sound away FANIN0 got to 1985rpm max not too sure what that Fan is, CPU fan? as thats the only one i have connected to the MB
thanks i got it, now to figure out what the CPU temp is
under Temperatures i get:
Motherboard
Core1, 2, 3, 4
Aux
and then some GPU info, guessing its the Aux thing? if so while listening to music and surfing its getting 30c
theres the temps
i dont have Prime, but if i am having heat problems should i really be running that?
thats what i was thinking, its the same temp as TMPIN0.
i heard TMPIN0, 1, 2 are for CPU, MB and outside case but i only have 0 and 1?
as the 0 and 1 are the same as Aux and Motherboard from Everest so i should be concentrating on that temp and not the core temps?
