yes..Okay thanks, so completely ignore the core temps - so i should just keep an eye on the Aux/TMPIN0 temps then?
Dear Gareth,
Correct, as long as you are within the voltage and temperature guidelines you are ok. The temperature that should be monitored is the overall CPU temperature, not the core temp.
Best regards,
Jesse
AMD Global Customer Care
nookay that might be why, dont you have the same case as mine?
if so how much space is there with that cooler in there - it looks VERY big
tbh its very big insideokay thanks, i might have a look at that case, might think about upgrading mine
how do you rate it?
