95c!! Asus formula and Q6600
18 Oct 2002
Manchester
Just got a Q6600 95w SLACR and a new Asus formula maximus with 0907.
Overclocked it to 3.2 gig and my temps are sky high!
Idle is between 44c and 46c, and full load shoots right upto 89c - 95c
I'm using the nvidia/zalman tritium cooler on full pelt all the time.
cpu has 1.45volts to keep it stable at that speed.
Do i need a new cooler, can these temps be right?
That can't be right. Get frying pan and start cooking fry ups. Seriously are you using coretemp? If so reseat cooler and make sure you have good contact
If they were real.. your CPU would have gone by now.. o.O
I have the same CPU and board as you with a TRU-120 Extreme and my idle temps are.. about 30-35 degrees.
Right,
Reseated the heatsink and put some fresh compound on and max temp has dropped to 69c and 75c
Still seems high???
Using core temp 0.97.1 to measure.
My cpu seems lame as it needs very high volts to get anywhere :(
