- 19 Oct 2006
I know the performance will suck but it will work right?
Also i had a 9600GT and according to gpu-z it wasnt pci-e 2.0 anyway![]()
Nvidia.com said:PCI Express 2.0 Support
Designed to run perfectly with the new PCI Express 2.0 bus architecture, offering a future-proofing bridge to tomorrow’s most bandwidth-hungry games and 3D applications by maximizing the 5 GT/s PCI Express 2.0 bandwidth (twice that of first generation PCI Express). PCI Express 2.0 products are fully backwards compatible with existing PCI Express motherboards for the broadest support.
It's backwards compatible with PCI-E 1.1, but the older VIA chipsets are v1.0 and spit the dummy if you try to run a PCI-E 2.0 card.PCI Express 2.0 products are fully backwards compatible with existing PCI Express motherboards for the broadest support.
Should be ok but if ots only for a couple of monitors id get the cheapest card you can such a 8400GS, no need to spend on a 9600GT
