9600K(F) Overclock
22 May 2010
Minibotpc
Afternoon!
Been playing about and managed a nice 5.1ghz all core @1.375v with LLC on high on a gigabyte Gaming SLI board. Temps are around 70c gaming and 75ish bench/prime... tried pushing for 5.2ghz but got a few BSOD's at 1.39v with high LLC.
Whats the usual(ish) voltage needed for 5.2ghz? Is it worth bumping upto 1.4v and pushing more LLC?
I'm on a custom loop with 2x240mm rads, 2 cards and a cpu in the loop.
Afternoon!
i wouldn’t push it as you probably at limit.
1.375v should put you at 5.2, if you can’t you are just at the limits of the chip. 90% of chips on the production run can’t do it.
I hear you, thanks for that guys. Will just keep it at 5.1 then, shame because thermals seem like it would allow me to go further.
