960m 4gb
23 Feb 2010
Hereford
Hi guys. I have a Lenovo Y50-70 laptop with the above gpu in it. Every now and again, I get really bad screen flickering and blinking. I assume it's a faulty gpu. Also in afterburner, my base and boost clock skyrocket for a second, and then go normal again whilst i'm sat in idle.
Also the temp readings go up and down in the graph constantly, from a normal temp, down to 0, and back up again. Can somebody please shed some light into what's going on? Thanks.
Also posted in the GPU section (hope that's ok mods)
Could this be an issue with the graphics card switching between internal and dedicated? Checked the drivers for both are up to date and there's no BIOS/firmware updates for the laptop?
I've set it to use the GPU rather than the in built in Nvidia control panel. And I have updated bios and graphics. Pretty sure it's going to be a loose cable or something as apparently it's quite common. But if I open it up, I lose my warranty.
