9650 oc advice
30 Nov 2007
Im after some advice please on q9650 oc using p5q pro board
Im looking for a base to start, volts, multi, fsb etc
running it on air with tuniq tower 120 extreme
Just general advice really if possible
personally i would use the chip's default multiplier, rather than a lower one.
Max voltage 1.35-1.37v (not sure about vtt and pll on 45nm chips).
Have a quick read on gtl ref volts too.
pll max should be 1.6v, but check after you set a value by going back into bios and looking at the system health/monitor (whatever it's called on your mobo).
vtt you shouldn't really go above 1.3v
As above: PLL 1.6 (although try to run lower than this)
VTT 1.3 (i run mine at 1.33)
Vcore no more than 1.4 (esp as your on air)
i take it that clocking a quad is different from a dual ?
all ive ever changed with my 8500 is vcore and dram volts
VTT ? :confused:
PLL ? :confused:
