'97 BMW 316i Compact wiper problem
6 Dec 2002
Liverpool
hi fellas,
jsut baught a 316i compact, and all of a sudden the window wipers have stopped working, front and rear, the squirters dont work either!
im thinking this could be a fuse but i havnt a clue were the fuse box is!! this is my first car btw, have worked on bikes before so have a fiar idea on what im doing.
btw these were defentetly working when i baught the car because as i couldnt work out how to turn the buggers off :D
any help guys?
Cheers
rear wiper right hand stalk dad once to turn on dab again to turn off
front wipers only work cont. if you are moving
take it to a bmw dealer, you will need them for service
e36, im guessing the fuse box will be under the bonnet like on mine, your user manual should tell you where it is and tell you which fuse is which :]
Could be the wiper control module
its behind the glove box. ;)
