970-1070 fps problem
16 Sep 2012
hi i got the msi 1070 and jumped into bf1 and as expecting way higher fps .....zero fps the sazme as the 970 at 1080p and mine has the micron memory help
i5 4690k @4.4ghz...msi z97 gaming 5 mobo....16gb of gskill ripjaw x 1600mhz ram
h100i gt cpu cooler temps fine max 53c while gaming ...corsair 750w builders modular psu nzxt s340 case 850 evo ssd 250gb ....1tb samsung hdd
hi thanks for replying but i do not know how i would know if the gpu was at 100%...should it be and when i check cpuid when gaming the highest recorded cpu utilizations are 86%
roff do you think i should turn off the cpu overclock as all i did to run at 4.4ghz was to increase multiplier and the max cpu voltage is at 1.185v
i did now see a fps difference since a reboot after installing graphics card im getting may 2-30 fps more in places and the game does seem to look nicer now is it ok for the cpu to max out or will i destroy it ...would you clock cpu further seeing as temps are great or would you just try to core parking thing if you was in my situation as i only built this entire pc about 6 months ago
what are your temps at mine idles at 42c my 970 was way cooler.Also if you play bf4 have you seen the low fps icon as that keep popping up all the time but my fps are around 90-120 so i im worried i may have a problem somewhere
