Thanks for that, so Peter fom nVidia in Santa Clara says you can have a refund. That just need to filter down the supply chain then.
the only thing they can probably do is improve the memory management and make sure that the the last 512mb does not need to be constantly accessed during gaming. which will essentially make it a 3.5gb card with 512mb reserved for OS. not ideal but not the end of the world.
I've been trying to wrap my head around this whole thing since Saturday. I'm genuinely not bothered about the difference in specs - I purchased my card on benchmarks and reviews.
I am however not happy about the stuttering over 3.5GB - performance drop sure but the stutters I've experienced really makes it unplayable. I can only see games getting better with textures so this will likely affect more and more games @ 1080p.
Doubt very much drivers will fix this unless they just decide to disable the final 0.5GB, however can they do anything with a BIOS update or is this really down to physical design?
This might be a stupid question but, if you don't ask, you will never know.
Ok so say NVidia could fix this and enable the last 0.5. Would this then put the card on level terms with the 980? I'm not very technical so forgive me![]()
LOL - That is ALL![]()
At the moment im singing sweet lullaby songs to my 970 , it needs the support in these testing times. Man Hug.
You guys DON'T want Nvidia to enable the last 512mb. Believe me those that don't have the issue will complain as well.
You go over that 3.5GB-3.6GB "threshold" the performance will tank and you will have every game stutter like there's no tomorrow.
The card is limped over 3.5GB end of story, it can't be fixed by any driver and whoever claims that has no idea what he is saying. The issue will be multiplied if "fixed" to access the extra memory on the driver level and those currently supporting Nvidia will also start complaining.
Cant answer that as 0.5 is not disabled.
You're a scaremonger, if a refund was to shut you up I'd pay it myself, but i dont think that would work.
It is good to see you and Gibbo in this thread answering questions.
I hope all goes well with NVidia so this issue is brought to a conclusion.
I also think the 970 is still the best card in it's class by a mile.![]()
It is a good job you don't own a ref 290X, give that a man hug and you will end up with 3rd degree burns.![]()
burn baby burnThe driver is forcing games to not access it.
The reason ? Because it's like running your GTX970 with DDR3
