Can I still return the card if I no longer have the box?
Yes you can, as long as the card is not modified or damaged in any way I can sort out a return
Cheers
Bailey
This whole thing has been engineered from start to finish so they think they could get off on technicalities if caught.
Swindlers, how come none of the OEMs saw the error either?
Sorry to be a pain but is there a date limit from when you bought the card? I bought it on the 14th November.
Update the first post with gibbo's updated reply how this is being handled by ocuk. If you start a thread atleast have the decency to keep it up to date.![]()
and all the NVidia fans are slating the 290x thermal output - becauswe 100watts is so much more isn't it, oh wait 3rd party coolers sorted that
really.
but lets ignore the thread and its real issue over how NVidia lied and got caught. again
bumpgate 2
I just got my RMA number, but it says it says the desired action of the RMA is to replace, which is pointless as one 970 is going to be the same as the next when it comes to this issue. I will get on to customer services
I returned my 2x 970's yesterday, to be fair I did come away with 2x 980's.
I just want to thank Gibbo and OcUK for outstanding customer service.
Even though I buy 95% of my equipment from you anyway this just proves what a great company you are.
because a cooler makes any different to heat output does it?
because an efficient cooler is better at dissipating heat than the reference one.
Anyone know if the refunds are cash or being done in the form of store Credit?
thermal output =! running temperature.
if the thermal output is 200w, then it'll be 200w whether it's water cooled or or passive.
ie, 290x will still dump a truck load more heat in to a case and if you dont believe me, go sit next to a 100w lightbulb for 10 minutes - they the extra heat being dumped by a 290x on top of a 970.
fail argument.
