The Asgard said:All depends if you want SLI?
If yes 680i.
kayone said:It won't be used for SLI, single GPU only.
- Best to just go ahead and hit 975X now then rather than waiting?
Looks nice, damn pricey though!The Asgard said:Having played with most of the top 975x boards I would recommend the ASUS P5W64 Pro. Rock solid. 450+ FSB. Little VDroop. Only downside its one of the most expensive.
kayone said:Yeah, why is it so expensive?
I was also looking at the Asus P5W DH Deluxe WiFi, which has also had some good feedback/reviews?
I wonder if nVidia can make a better LGA775 chipset than INTEL? That would be something!airchie said:1. Should I just buy a 965/975 chipset mobo now or wait for 680i?
Hi, does the P5W64 Pro suffer from the reboot issue which plagued the P5B/P5W DH motherboards?The Asgard said:Having played with most of the top 975x boards I would recommend the P5W64 Pro. Rock solid. 450+ FSB. Little VDroop. Only downside its one of the most expensive.
Nelly said:Hi, does the P5W64 Pro suffer from the reboot issue which plagued the P5B/P5W DH motherboards?
Also Ive noticed the new 680i boards support upto 1333 FSB, do you think when the newer CPU's are released that the motherboards that support upto 1066 FSB only need a bios update to support those CPU's?
but i remember when i bought my DFI Lanparty NFII, i still had an XP2000 chip, but since ditching everything else and upgrading ive kept the board and its serving me well, i know how to clock it etc. etc. and the only reason i'll be upgrading is due to graphics restrictions.Nelly said:Hi, does the P5W64 Pro suffer from the reboot issue which plagued the P5B/P5W DH motherboards?
less agressive memory settingsNelly said:& there is a loss in performance. Why is this?
I don't know if it happens at 400 but I have been reading on forums about 975s being faster than 680is so it sounds similar ...Does the 680i Motherboards also suffer this performance loss over 401 FSB?
Cool, will be interesting to see what happens anyway.BUFF said:less agressive memory settings
Maybe once the BIOS starts to mature that will improve.
Flanno said:Do you still recommend the Bad Axe, as I remember you posting about it being the most reliable board you every used.
