- 6 Oct 2012
- (do-or-die) Wye, Ashford, Kent, UK.
hi,
i have a 980 with an i3 2130 and 8gb of ram.
i am using a 2560 144hz g-sync monitor.
i was playing dishonored at 144fps, and i see frame drops down to 80fps, usually in outdoor areas with lots of detail and distance.
this isn't random, as it is always the same objects or group of buildings.
i was told by someone that has the same gear (apart from owning an i5 not an i3) that dishonored should run consistently smooth at 144fps on a 980.
i though it might be bottlenecked by the cpu, so i ran hwmonitor in the backgound after playing for about 30mins.
the cpu temp seems to peak at around 56c and the gpu at 69c.
this does not appear to be bottlenecking, does it?
