- 4 Jan 2008
I installed my 9800GX2 tonight, installed the latest drivers from Nvidia's site and rebooted. I then ran several stability tests and benchmarks, all of which went well.
I then shut down to neaten up the cabling a little and screw in the PCI bracket. I replaced the side panel and powered up. The computer POSTed fine and the Vista loading bar came up and was followed by the blank screen which preceeds the logon screen. The only difference to a usual boot, though, was that where as this screen usually only lasts 2-3 seconds, this time it remained blank for over 10 minutes. I powered down and started the computer again and was faced with the same blank screen. It has been this way for around half an hour and is still blank as I type this message.
Any ideas what could be causing this problem and what could I try doing to fix it?
My specs are as follows:
Asus P5W DH Deluxe
Q6700 cooled with Arctic Freezer 7
BFG 9800GX2
Creative Soundblaster Audigy
2GB Crucial Ballistix 1066 MHz
1KW Enermax Galaxy PSU
150GB WD Raptor
500GB Some WD HDD
A couple of Lite-On Optical Drives
Also, my PCI-E Freq is at 105, my VDIMM is at 2.1V and the RAM is running around 200MHz below rated, so I dont think this will be a problem.
Asus P5W DH Deluxe
BFG 9800GX2
150GB WD Raptor
500GB Some WD HDD
