9800GX2 fan speed
16 Oct 2007
Worcestershire
Whats the fan speed at idle ? mine revs up when I start the PC but is quiet from then on, goes to 65 degrees when playing Crysis but I 've got the case side off
or it would be higher for sure
Nvidia Ntune shows the fans as System 31889rpm Nforce 675rpm Aux2 18rpm
Not heard it ramp up speed yet tho, what temp triggers it?
Not sure on the speed or temps on mine, but mine definatly ramps up when playing Assassins Creed for example and is audible
Idle its silent and most other games its pretty silent too
With these & similar cards exhausting out of the side & into the case is a bad idea, anyone modded their side panel to improve things? my side fan is too high up, I've got a spare side that fits & I might try fitting a fan with a short duct so its sucks directly at the card & see how much diff it makes
