9800GX2 - Too much voltage???
7 Feb 2004
I am having problems with my graphics card and think its a power issue.
Can someone advise me on if this looks ok or not:
Hardware Monitoring : ITE IT8718F
Voltage CPU : 1.41 V
+3.3V Voltage : 3.33 V
+5V Voltage : 4.91 V
+12V Voltage : 13.77 V (This looks bad to me)
DIMM : 2.24 V
VBAT : 3.31 V
If there is a problem what can I do? What would I remove to compensate?
Thanks
First of all, what is the graphics card problem? Second, where exactly are you getting these readings? The BIOS is virtually always wrong. Finally, I doubt it is a power issue.
What would i need to do to fix then? What do I check with Everest? I downloaded the trial
It shows the same. But missing some bits because its trial only
Everest reading:
Voltage Values
CPU Core 1.41 V
+3.3 V 3.33 V
+12 V 11.99 V
+5 V Standby 5.24 V (This one is over)
VBAT Battery 3.31 V
DIMM 2.24 V
GPU1: GPU Vcc 3.35 V
GPU2: GPU Vcc 3.31 V
