- 23 Aug 2007
- Rothesay
Ok as some of you here know i sent off my 9800 GX2 at the beginning of January to be repaired/replaced and finally received it back approxmeatly 4 weeks ago.
I now have a problem with it again earlier today it would not boot into windows properly with the nvidia drivers running but would when running safemode.
It seems their is an issue with one of the GPU cores and device managment is reporting a problem
Also as some of you also know i run F@H 24/7 and monitor temps etc very closley and since receiving back the 9800GX2 i have yet to see its temps go above 85c for this card is extremley good.
Does it sound like ive killed the card again or has leadteks repair just not been good enough.
I have tried three different versions of the nvidia driver and get the same responce.Windows has stopped this device because it has reported problems. (Code 43)
