stigggeh said:yeah there is no pipes to unlock, so just overclock it.
you get a really small boost by flashing the bios due to enhancements in the core, your pro needs to have an R360 core before flashing bios to XT. Imo its not really worth flashing.
Topitoff said:Only way is to remove the heatsink and see what it says on the core.
5bjoshua said:Go get ATItool and it says what the core is on that software.. On options theres a properties bar and it says on there, may say it on something else but you get the jist...
marc2003 said:no it doesn't. it only tells you what the bios is. not the core. only way to find out for sure is to whip the cooler off and have a looky.![]()
5bjoshua said:Well it does it with my X800XT PE and my 9600SE.
