Hi,
Looking to do a new build and upgrade from my 3900X to a 9800X3D. I've already bought some of the components and others still deciding.
Looking for a sense check of the build I was going to finish putting together and any feedback:
* Fractal North XL TG - Bought
* 9800X3D - Bought
* Noctua NH-D15 Chromax black - Bought
* Corsair RM850X (2024) 850W - To buy
* Noctua NF-A12x25 case fans - To buy
* 3080 Ti - Will be moving over from current build
The two components I am still going back and forth on, the mobo and the ram. For the ram, from looking at reviews/guides/forums etc.. it seems that DDR5-6000 CL30 is the best memory to get. I am looking at 2x32GB (apparently using 2 sticks is better than going 4, say 2x16 now and a further 2x16 later for instance).
The memory on the short list is:
* Corsair vengeance (CMK64GX5M2B6000Z30)
* G.Skill Trident ZZ5 NEO/RGB (I am not fussed about RGB at all and usually that adds clearance isssues?).
For motherboards, probably the most difficult part to pick, the short list is this:
* Asrock X670E PG Lightning
* Gigabyte X670 Gaming X670
* ASrock X670E Pro Rs
* Asrock X670E Steel Legend - Maybe less keen on the styling of this board
* MSI MPG X670E Carbon WIFI - Probably my first pick
* Asus Rog Strix X670E-A/F - Probably my 2nd pick.
Any thoughts on the above build?
* 9800X3D - Bought
