I'm after some advice on a completely new build to replace an old PC that's just died after many years of faithful service. I'm considering the 9800X3D & ASRock X870E Nova, will run off the integrated GFX unitl I can get a 9070XT.
Main uses will be gaming (once GPU purchased), Transcoding, some light virtualisation labs
I need some help with the additional components of the build & any recommendations that you may have.
Case
- Must be able to fit at a minimum 2x 3.5" drive into it, but more would be great.
- Will sit on the floor under desk
- Old case is an Antec P280
M.2. Boot
- Any real world difference to using a Gen 4 vs Gen 5?
CPU Cooler
- Prefer an AIO
RAM
- 64GB
PSU
Fans
Thermal Paste
Anything else.
Not against changing the motherboard to something else if it's considered a better option, but will need more than 2x SATA3.
Budget for the base unit excluding the GPU is in the £1500-2000 reigon. Don't need peak performance, but willing to pay for things that are in the sweet spot.
Thanks in advance.
Case
M.2. Boot
CPU Cooler
- Prefer an AIO
RAM
- 64GB
PSU
Fans
Thermal Paste
Anything else.
Thanks in advance.
