9800x3d spec check
16 Jun 2005
In the middle
Hi all, just playing around at the moment, what do people think about this build? It comes with an 850w psu, would that be ok with a 9800x3d and a 7900xt?
My basket at OcUK:
  • 1 x OcUK Gaming Osprey - AMD Ryzen 7 7700X, RX 7900 XT Gaming PC (SKU: FS-1FR-OG) = £2,365.03
    • Case: 1 x Phanteks Eclipse G500A D-RGB Mid-tower PC case - Satin Black
    • Processor: 1 x Build Stock AMD Ryzen 7 9800X3D Eight Core 5.20GHz (Socket AM5) Processor -
    • Memory: 1 x Corsair Vengeance EXPO 64GB (2X32GB) DDR5 PC5-44800C40 5600MHz Dual Channel Kit - Black (CMK64GX5M2B5600Z40)
    • Graphics Card: 1 x Sapphire Radeon RX 7900 XT Pulse 20GB GDDR6 PCI-Express Graphics Card
    • Cooler: 1 x Kolink Umbra Void AIO 360mm Performance ARGB CPU Water Cooler
    • M.2 Solid State Drive: 1 x WD Black SN770 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T3X0E)
    • M.2 Solid State Drive: 1 x WD Black SN770 2TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T3X0E)
    • Operating System: 1 x Build Stock Microsoft Windows 11 Home Advanced - Systems
Total: £2,365.03 (includes delivery: £0.00)​
Hi.
Generally there's nothing wrong with your choices but do you need 64gb of memory?
850w would be enough but you can makes changes if you wish to up the PSU by contacting Overclockers.
Phanteks g500 case is nice but with the koolink aio will the RGB fans match ? The phanteks glacier one aio adds another £68 to your build if you swap it out.
Would take the Asus Radeon RX 7900 XT TUF OC option over the pulse at the same price.
Thanks! I assumed the koolink aio would match as that's part of the standard ocuk build.
Noted on the Asus card rather than the Saphire.
Your welcome.
You never know with RGB fans, there may be some variations which if your like me would do my head in.
True, Phanteks aio in a Phanteks case might have a better chance of a match.
the new phanteks one is very cheap and come with 3 x m25 ARGB fans - can be had for £80...
i have to say hands down i think Phanteks ARGB is king i switch to Lian Li and im in the prosses of switching back
