- 1 Apr 2010
Thermal Grizzly Kryonaut which is non conductive as far as i'm aware.
Well you can rule that one out then. Good luck with the RMA.
If it was like that then it looks like you did not cover the corner with thermal paste at all... so that part probably overheated due to having no thermal paste on it...
MSI allow cooler removal.
This was still valid when I asked in late May.
It just looks like one of those things, cooler removal had nothing to do with it. RMA time - be warned MSI are sloooowwww.
Finally I would play it safe and get a different PSU. OCZ have a fairly rubbish rep when it comes to power supplies.
Only kidding there not EVGA sadly. Let us know please.
Just bought myself a MSI 980Ti 6G from the MM, it should be covered until mid 2018 but don't want this happening![]()
. Using 2 MSI 980ti's myself and the temps are great so never had a reason to change the paste. I run my 2 at the max voltage allowed on afterburner too but not had a problem. You might have even forgot to tighten 1 corner but I wish you luck mate MSI customer service is really good so you never know.
