Not sure if I can post but here is my gpu z...
http://gpuz.techpowerup.com/15/07/23/7qk.png
My overlay is reporting 1420 MHZ ingame, slightly confused.
Can I force anything in afterburner to help? or maybe use another program?
I feel lucky now, got 2 MSI cheapo reference which can run @ 1520 78 & 71 ASIC's.
Is that instability power related (hitting max & throttling) - Ive found by putting my power limit stability has increased significantlyGood work. My 70.3 asic seems to bench well at 1506..but ain't game stable. I think its nearer 1430 for me to be 100% stable in heavy games like pcars.
If you drop that to +500 (a good overclock) you may be able to get the core higher.Okay so all in all a 1420 boost overclock isn't that bad? Considering i've managed now a 700mhz memory overclock?
Yeah, I had to flash my bios to up the power limit to incrase stability, but I've got them under water & had to .. do horrible things to one of them to remove the stock cooler so no RMA for me.Yeah I hit the power limit quite a bit. But ive set it to 109% max in AB.
I have to say, using a circular saw on a £500+ graphics card to cut through metal wasn't a fun thing to do half way through a build
One slip & I'd have chopped off the end of the board.If you drop that to +500 (a good overclock) you may be able to get the core higher.
That's the thing, I did the core clock first, max I can get is +210.
My heaven benchmark score was 2700, does that seem normal? what do you guys get @ 1080P?
use afterburner and run a game for a bit, then check the graphs - that'll tell you your true boost value.
So far i've only got +200/+500 on my ocuk reference and that's boosting to max 1466 with +25 volts, but that's hitting the power limit (106%) a lot and i'm getting some strange behaviour in gta v so i might not be completely stable yet.
Asic 83.9
