980X water block
10 May 2010
Hampshire
I am after an EK water block for the 980X processor which is the better one to go for at the moment? your help is very much appreciated
regards
duesix
As PualyD says get a supreme hf, the full nickel/copper blocks are the best but only a smidge better than the standard hf. Ocuk dont have the newer square plexi/acetal hf blocks on sale yet, probably trying to clear the old stock first.
they are due in in a few days
Nath has an order in the works from EK so it should be soon.
as said. the supreme HF is good.
the supreme HF CU is supposed to be the best. check the review here from bundymania. his reviews are very very accurate.
guys i cant thank you enough for the replies, i know reviews are good to read but sometimes it helps to hear it from others too.
cheers for the help
