Hi all...
I decided to delid my 9900K instead of switch for Z490. I purchased a full delid/DD kit from RockItCool, and i successfully managed the process. I have custom water cooling, there is a EK Supremacy EVO on the CPU, which should be good for DD cooling. Anyway, i did set it up, and found out, there is no contact between the block and the die, after the startup the CPU temp is already 85, so i switched it off asap. I followed all the instructions, what they share about the installation on YouTube. Any advice, how can i make this **** works?
