9900k- no display
2 Jul 2008
Near London
Hi guys,
I bought a 9900k to replace a 8700k. I thought it would be a simple drop in replacement. However, I cannot get any display from the new cpu. Are there any settings i should change in the bios before putting the new cpu in?
Any help appreciated.
Thank you, I will check that in the morning, could swear I had the most up to date bios already installed though.
This evening I have tried a cmos clear, but still a blank screen. Tried the hdmi lead in both the graphics card and onboard hdmi. Also checked to make sure there were no error lights on boot, all clear. Very strange.
D
Most likely bios update needed but
Did you clear the CMOS using the jumper on the motherboard , taking out the bios battery and disconnect power cable to the psu.
Leave for 10 mins before trying.
Thanks Micky. I cleared cmos with just a screwdriver over two pins. Will try battery removal, then check bios etc.
