9900K - Tjmax 99C or 100C or 115C?
22 Mar 2017
Poland
Have an question. My 9900K is oc to 5ghz with Noctua NH-D15. Stable vcore 1.320v. During realbench stress 2hours run max temps are 80-93+-. But when i run next 2 hours stress tests ,temps are 80-97+- and i saw in realtemp peak to 99C sometimes. GREALTEMP shows in red LOG.
But why realtemp show log in red when temp peak to 99C? Is this because 99C is thermal point TjMax? or 100C is Tjmax or 115 Tjmax?
Games temps are very low 60-70C.
My question. Is this normal for that temps peak on realbench? Overall are 80-90+-C in realbench,but after very long run realtemp show max 99C.
Can i use this cooler on games ? And i stop using realbench if all is stable.
Mobo is: Asus Prime Z390-A
2 hours of RealBench is a bit over the top, 30 minutes should be enough to get an idea of stability. Air cooling a 9900k is going to be testing at the best of times, if your temps max out at 60-70c when you game that's very good.
If you want to run 5.0ghz, try using an AVX offset to reduce max temps when encountering AVX/FPU instructions.
