You might gain a few fps in games like WDL or facry6 but most won't really show much of an improvement especially for the money it will cost. Personally I'd hang on another year till DDR5 is matured and prices have settled down by which time AM5 and Raptor lake will be out.Is there any point or gains to be had?
Scratching my head whether investing £1k into a new platform is at all worth it?
Disregarding everything else and basing it purely on gains.
Some gains, zero point.Is there any point or gains to be had?
Thanks mate, that's helpful!up to 9% gains game dependant at 1440p, probably not enough to upgrade imo and would want more than a 9% uplift for £1000+ outlay
use this graph as an example , doesn't list the 9900K but does list the 10700K and the 2 processors are basically identical for gaming needs
https://www.techpowerup.com/review/intel-core-i7-12700k-alder-lake-12th-gen/17.html
yeah 9% is defo not worth the money. I would want at least 15-20% minimum, generation to generation leap is so minimal these days in gaming performance at the higher resolution being more gpu bound so makes these decisions rather difficult.
I'm well and truly lubing up early for a 4090 at msrp if possYeah would want at least a 15% uplift in performance from a cpu upgrade but as you say at the higher resolutions we are not quite there yet at 1440p and its even worse at 4K ( >1.5%) so makes upgrading a CPU not an easy decision unless you are chasing the highest benchmark scores etc then there is maybe a case for it but for general gaming the thought of a £1000 outlay for such a small fps increase just doesn't make sense. What we need are quicker / more powerful GPU to actually utilize the cpu we have now at higher resolution, id be saving that £1000 for the inevitable £2000+ 4090FE which should actually give a noticeable performance uplift albeit at a ludicrous price![]()
I'm well and truly lubing up early for a 4090 at msrp if poss. I was "lucky" (if you can even call it that) to get a 3090 on launch day lol. I think the biggest deciding factor on what i end up with will be whether Eth mining ends in 2022 which will decide availability to an extent! I wanted a 3080 but ended up with a 3090, i'll want a 4080 but probs end up with a 4090...
